Re: Farmall M Cylinder head
Posted by Red Mist on July 27, 2010 at 17:34:56 from (67.142.130.16):
In Reply to: Farmall M Cylinder head posted by Nebraska Kirk on July 25, 2010 at 21:56:41:
Nebraska Kirk said: (quoted from post at 21:56:41 07/25/10)
DaleKOE said: (quoted from post at 19:30:17 07/25/10) how many pounds of torque should be used when setting a head on a farmall M and is there any order in which it should be done?
The head bolts need to be torqued to 110 ft/lbs. You must start in the center of the head and work in a circular pattern towards the ends of the head. First torque to 1/2 of final value, then 3/4 and finally full torque. Retorque with the engine warmed up to operating temp.
Beautiful answer, Kirk.
