Re: OT - Disposing of used oils/fluids
Posted by Roger46 on July 27, 2010 at 17:49:00 from (72.101.19.55):
In Reply to: OT - Disposing of used oils/fluids posted by Marty from MN on July 26, 2010 at 20:37:22:
I take all of mine to the local oil recycle place including the heavy transmission oils. If I have staight diesel fuel I take to one of the local gas stations that heats with oil. As for oil with water and even gasoline, in the winter time they get lots of water and gasoline with all the oil brought in, but probably not as much as what is in old tractor drainings. If you have the right container with a bottom drain, you can drain off most of the water and antifreeze. Roger
