Re: 606 International Tractor
Posted by CNKS on July 27, 2010 at 18:19:28 from (216.144.104.128):
In Reply to: 606 International Tractor posted by Gary Schupbach on July 27, 2010 at 17:32:42:
My 460U clutch wears out my left leg. Gears clash because of main clutch/TA adjustment, although mine still clash after new clutch and adjustment as good as I can get it. Basically the same rear end and transmission as was in the M, which used 90W. There is excess play in the linkage. Clash is worse when the oil gets hot. Might change to 20W trans-hyd fluid, although that is not recommended. Hytran or equivalent is more like 10W. Your 606 is very similar to my 460U. No more real problems than the typical old tractor. You will find water in the transmission and hydraulics. If gas, it will use a lot.
