Re: M light Switch question
Posted by Owen Aaland on July 27, 2010 at 18:24:48 from (207.13.114.172):
In Reply to: M light Switch question posted by Hobo,NC on July 27, 2010 at 17:57:28:
The resistor was used to provide a low charge circuit for tractors that used generators with a cut out switch. You don't need it with an alternator or generator with voltage regulator.
The oil pressure switch is nice for tractors with magnetos. Rather overkill for one with battery ignition. For those a diode is easier.
