Re: M Governor Repair or Replacement
Posted by Clarkbug on July 28, 2010 at 03:03:49 from (12.189.32.54):
In Reply to: M Governor Repair or Replacement posted by TWheat on July 27, 2010 at 19:19:38:
F-Dean said: (quoted from post at 22:19:38 07/27/10) The governor on my M does not idle down when I push the throttle in. I believe the problem is in the Governor.
How difficult is it to rebuild? Who has governor rebuilding kits? Or is it better to buy a rebuilt one? If so, where do you recommend?
Before you tear into the governor, look at the carb. Make sure that the tab on the end of the rod that connects the governor to the throttle plate is lined up correctly. It could be that these are no longer aligned, the small fitting on the end of the throttle shaft could be broken, or maybe the shaft is binding in the carb.
