Char-lynn on super MTA
Posted by ol-shep on July 28, 2010 at 05:15:33 from (206.162.192.39):
When you put the motor in the bracket where the gauges are is there some sort of shims to make it line up with the shaft. I have the proper wobble joint connector but when you start drawin the bolts down it puts a strain on it.Any one with a picture of whats right? Just dont want to knock out the seal.Thanks
