Re: IH 806 Injector pump question
Posted by dao on July 28, 2010 at 07:49:10 from (206.125.157.109):
In Reply to: IH 806 Injector pump question posted by Mel Shaw on July 27, 2010 at 18:42:57:
you'll need lines,pump,mount and driven gear inside front of engine. I called m&s in sikston mo. and they sent me everything i needed. don't have to use ether any more. its well worth the time. good luck.
