Re: M Governor Repair or Replacement
Posted by Janicholson on July 28, 2010 at 14:14:00 from (199.17.55.140):
In Reply to: M Governor Repair or Replacement posted by F-Dean on July 27, 2010 at 19:19:38:
There is a screw near the tube from the governor. It adjusts the idle speed. If it does not, it could be that the throttle plate is loose and getting stuck in the carb bore. A leaking intake manifold will also allow a speedy idel. Jim
