Re: 1954 International Harvester Super C Ignition Switch
Posted by Bob on July 29, 2010 at 20:27:55 from (69.178.228.68):
In Reply to: 1954 International Harvester Super C Ignition Switch posted by Walter Wallace on July 29, 2010 at 20:06:44:
Are you replacing the LIGHT SWITCH:
Or the IGNITION SWITCH:
BTW, if you are working with the ignition system, the term for the resistor is BALLAST resistor.
