The ignition switch is a push pull knob at the dash box. The starter switch is on the starter. (it would cause you to need to crank it)
The ignition coil is near the distributor. The coil main wire goes to the center of the distributor cap, the Plus goes to distributor side small terminal if positive ground, and the negative side small wire goes to the distributor if it is negative ground.
The starter switch (if stock) has two wires only connected to the battery cable terminal.
If it has seen rewiring, there is going to ne issues that need your full understanding of the names of things (without malice) This link should do the trick. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
