Pull off a plug wire and hold it away from the sparkplug about 1/4". Then have a helper to make an attempt to start the engine. If there's no fire rub the points with a piece of 320 wet or dry then see if the engine will start. If it starts you've found the problem. If there's still no fire to the plug you need to use a volt meter to see if you have battery voltage at your coil with the points open. You need the ignition switch in the on position too. Look at those points if they're pitted replace them and the condenser.
Run a separate wire from your battery to your coil then see if the engine will start. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
