Re: w4 stuck engine
Posted by Frank M on July 30, 2010 at 10:48:17 from (67.142.168.27):
In Reply to: Re: w4 stuck engine posted by Farmer Bob on July 17, 2010 at 21:28:32:
I used the ATF/Acetone mixture on my recently acquired Farmall M. It had been sitting for at least 10 years. I poured the mixture down the cylinders (through the spark plug holes) and let it sit for about 2 weeks. When I wasn"t able to turn it after that, I drained and pulled the oil pan and sprayed the solution up into the engine, crank and cylinders. Turned over the next day. Thanks FarmerBob
