Farmall Tractors Discussion Board
Re: M.D. Farmall
Posted by S Bowen on January 01, 1999 at 13:52:34:
In Reply to: M.D. Farmall posted by Scott on January 01, 1999 at 10:33:52:
These usually go for 1200 to 2500 depending on the condition. Alot of them will have cracked heads.They can usually be welded though. They start easily if the linkages are correctly adjusted on the gas/diesel switch overs. If you are wanting a M series to collect the MD is a good choice. If you want one to use on a daily basis for light work, I would get a gas M
Post a Followup
: Re: Re: M.D. Farmall
