I would use a wall anchor bolt (Moly-Bolt) that is setup with two ears that fold back against the shank. ( think it is 5/16 course threads) Put a fender washer (large diameter with hole that fits the bolt) and a nut on the bolt shank to assure it will not drop into the crankcase. When it is pushed through the hole it expands with spring pressure to push the ears out sideways.
I would then tighten the nut and fender washer so it holds against the casting.
After tightening, I would put an additional nut on the bolt to keep it from backing off.
Then I would bend the bolt to assure it was centered in the fill hole, put on the cap (Thumb tight is all it ever needs) and cut off the excess shank. A little filing to smooth and there you are! Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
