Re: Various C Questions
Posted by gene bender on July 31, 2010 at 15:31:53 from (207.177.56.91):
In Reply to: Various C Questions posted by James K on July 31, 2010 at 12:41:13:
Remove the tires and sand blast then you will see if they are worth saving. Prime and paint and no fluid when putting tires back. Your ring gear is probably shot. Remove the starter and turn engine over with the crank to check the teeth if they are bad split the tractor and remove the ring gear turn it over and get the good side towards the starter been done many times.
