Re: Steering Vertical shaft on an H
Posted by wayne in mn on August 01, 2010 at 16:39:25 from (24.179.173.171):
In Reply to: Steering Vertical shaft on an H posted by David A. Smith on August 01, 2010 at 16:23:53:
Support the tractor carefully so you can remove the front wheel assembly. Then the effort exerted to drive the shaft downward will not have to move the weight of the wheels also.
Put the nut on until it is flush with the end of the threaded shaft. Take a LARGE hammer/sledge and hit it HARD. Think of the strong man at the county fair trying to ring the bell using a sledge hammer!
