In such instances I prefer using a brass hammer. With a brass hammer you can deliver a harder blow without damaging the object you're striking. Nevertheless, I would leave the castle nut on & hit it, cheaper to replace the nut if you damage it instead of the shaft.
Also as stated, you need to get the weight off the tires. If you're taking the shafrt out you might as well as go ahead & remove the front bolster now as it will have to come off to get the shaft out.
To remove the the bushing inside the Apost I use a sawzal & sp;it it on one side. Just be careful not to cut into the A post
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
