Re: Farmall H steering failure
Posted by john fleming on August 01, 2010 at 18:34:08 from (75.182.111.210):
In Reply to: Farmall H steering failure posted by Larry Lind on August 01, 2010 at 17:02:00:
if the upper boster shaft needs to be replaced check parts number stamping located on flange as there is parts number and serial# break i am wanting say 39-45 are the same, as one is shorter then the other ,later year over early. will cause wheel shinny i know been there done that 4 mo.ago no fun on a69 yr old good luck. John
