Re: Steering Vertical shaft on an H
Posted by Zachary Hoyt on August 01, 2010 at 19:41:36 from (173.86.126.167):
In Reply to: Steering Vertical shaft on an H posted by David A. Smith on August 01, 2010 at 16:23:53:
If the front wheels are still on the ground you need to jack up the front end so that they're not and then all it should take is a couple good whacks. The top of the shaft is tapered and splined so it comes off pretty fast, at least on mine. I use a 16# sledge when I want to hit something like that, it does a good job.
Zach
