Re: Farmall H steering failure
Posted by MN Scott on August 01, 2010 at 20:11:26 from (12.157.197.233):
In Reply to: Re: Farmall H steering failure posted by Larry Lind on August 01, 2010 at 17:58:41:
Check the four bolts that hold the lower bolster [the part the wheels and hubs fasten to] to the upper shaft. There should be one bolt in there with a raised head , about an inch longer than the other bolts. This special bolt keeps you from turning the front wheels to far thus disengaging the gears. I bet your missing yours. To fix jack your tractor up and turn the wheels until the half gear meshes with the worm gear. Turn the steering wheel until the wheels face forward. The worm gear should be centered in the half gear. Then find yourself the special bolt or be careful not to turn your wheels past the disconnect point of the gears.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
