Re: Steering Vertical shaft on an H
Posted by mkirsch on August 02, 2010 at 05:16:11 from (64.80.108.55):
In Reply to: Steering Vertical shaft on an H posted by David A. Smith on August 01, 2010 at 16:23:53:
Well, first off you gotta remove the gears.
Pull the pipe cap off the front of the gearbox, roll the steering shaft out, and remove the gear from the vertical shaft. It should slide right off.
Now jack up the front of the tractor. It should FALL out. There is nothing holding it except the castle nut on top of the gear.
