you can fabricate a puller from some 3/8 or half inch flat stock. drill 2 holes on the outside so the puller can bolt to the threaded holes where the cover mounts, then in the center over the bolster gear , drill and tap the flat stock or weld a nut to it for a half or 3/4 inch bolt. bolt it up tighten the center bolt to put pressure on the bolster shaft, then with the tractor jacked up, give the bolt a whack or 2 and it should drop out the bottom.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
