Posted by pete 23 on August 02, 2010 at 17:12:53 from (173.87.8.216):
In Reply to: Super H Govenor parts posted by Justin Kuck on August 02, 2010 at 15:20:20:
Are you saying that you have the high speed stop screw backed out as far as it will go and linkage is pulling it to where the arm contacts the govenor housing. It would take a lot of wear in those spring holes to give you a problem. Are your weights and pins in good condition?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
