Posted by pete 23 on August 02, 2010 at 17:22:21 from (173.87.8.216):
In Reply to: 856 D engine noise posted by Icuby on August 02, 2010 at 10:56:04:
Can you hear the noise when you are cranking it over with the starter with throttle shut down.May have to put your ear to the oil filler while doing this. If so, you have an engine problem. If not, you may have an injection nozzle problem. Do you see any sign of a puff or uneven fumes out of crankcase breather tube, would indicate piston problems. I would remove one oil filter and inspect for any metalic material. Also, do not over look the possibility of an injection pipe touching some other metal as that will make them sound like an engine knock sometimes.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
