Posted by El Toro on August 02, 2010 at 17:30:02 from (74.103.74.58):
In Reply to: C won't start posted by Curt W on August 02, 2010 at 16:54:25:
You need to measure the battery voltage at the battery when cranking for a start. Your battery voltage may be too low for the ignition when using the starter. When you pull start it you're not draining the battery. You could probably hand crank it and make it start. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
