Posted by Owen Aaland on August 02, 2010 at 18:54:53 from (65.165.246.191):
In Reply to: 856 oil leak posted by mkirsch on August 02, 2010 at 18:33:34:
I think you are referring to the transmission brake, not the parking brake. The parking brake is located under the range transmission cover, just in front of the seat.
There is an O-ring on the shaft that operates the transmission brake. To replace it you need to drain the transmission oil and remove the bottom cover. There is a clip that holds the transmission brake lever in place and a short pin through the cover into the shaft that holds the shaft in the cover. There is also a woodruff key between the shaft and the brake pad lever. Once the pin, clip and woodruff key are removed the shaft can be withdraw from the cover and the O-ring replaced.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
