Re: Super H Govenor parts
Posted by ROGER F30 on August 02, 2010 at 20:05:53 from (74.126.64.106):
In Reply to: Super H Govenor parts posted by Justin Kuck on August 02, 2010 at 15:20:20:
i find that a lot take a cotter pin the size of the wear hole cut it just long enough to stick through open it a little if this does not get the rpm you want go to the nuckle above the gov under the breather tube a little adjustment here goes a long way
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
