Re: International 606 diesel need help bleeding fuel lines
Posted by Jimmy King on August 02, 2010 at 21:39:14 from (66.119.9.207):
In Reply to: International 606 diesel need help bleeding fuel lines posted by reltor on August 02, 2010 at 19:46:47:
On the top of the fuel filter canisters are bleader screws 3/8 or 7/16 I don"t remember which open them and wait until no air comes out it may take a while because the filters are empty. then there is a screw on the top of the pump open it and wait until no air come out. Then crack the lines at the injectors and start cranking. After it starts you may have to crack the lines one at a time to remove all air.
