Re: A won't start
Posted by KWSUPERA on August 03, 2010 at 09:29:34 from (173.15.146.29):
In Reply to: Re: A won't start posted by Bob on August 02, 2010 at 22:52:05:
I think that your starter drive is stuck. In other works the starter never disengaged. You can try rocking the tractor back and forth a bit in gear and see if it comes out, tap the starter with a hammer to see if it disengages, or just take the starter bolts loose and pull the starter out to disengage it.
