Re: 806 clamp on duals
Posted by mkirsch on August 03, 2010 at 09:42:45 from (64.80.108.55):
In Reply to: 806 clamp on duals posted by jdetig1 on August 03, 2010 at 07:56:46:
Use 'em, don't abuse 'em, and you'll be just fine.
The clamp-type hubs on an 806 are its weak point. If anything that's what would break if you romp on the duals too hard. Newer wedgelock hubs are much stronger.
We ran clamp-on duals on a 1066 that had to been turning 165HP. Only thing you had to worry about was using the brakes to turn. That would cause the wedgelock hubs to slide out on the axle a little. Normally it was only an inch or so but such a pain in the wazoo to put back...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
