Re: Sprayer Recommendation
Posted by Haas on August 03, 2010 at 18:13:27 from (75.216.126.72):
In Reply to: Sprayer Recommendation posted by David A. Smith on August 03, 2010 at 05:12:15:
I got an Ingersol Rand HVLP gun at Lowes a few years back. It's worked well, and if you get the paint thinned right, not a problem with runs. A lot easier to get good coverage without runs than using aerosol cans. I think the gun cost around $80. Be aware that the HVLP guns take a fairly large air volume, so be sure you have enough compressor. You'll need a water trap in the air line and bleed the compressor tank frequently to let off the water. Especially in the summer when humidity is high, you will be surprised at the amount of water accumulation in the compressor.
