cub trans/final drive noise.
Posted by d. coleman on August 03, 2010 at 19:26:56 from (74.32.207.77):
i know this subject has come up not to long ago, but here goes again. just got my 53 cub running after a mayjor engine/trans/final drive o/h. engine runs like a top. trans. had 4 new bearings and differental was shimmed as per IH shop manual. both final drive assemblies were totally disassembled and cleaned and reassembled with new seals. all required shimming of f/d bearings was carried out as per manual. now when i drive the tractor the trans.or l/h final drive makes a loud noise. seems to sound worse when turning to right or in reverse. no problem with trans. going into any gear or with pto engaugment. did fill trans with hyguad trans/hyd. fluid instead od 90wt. gear oil. any insite into my delima? thanks for the dry sholder. d.coleman
