Re: Bleeding 466 Lines
Posted by pete 23 on August 03, 2010 at 21:00:11 from (173.87.8.216):
In Reply to: Re: Bleeding 466 Lines posted by Stuart on August 03, 2010 at 11:24:14:
In that case the problem would be that the trapped air is before the delivery valve and not after it. Even with the Roosa Master pumps, if you run fuel through them after assembly you can hook all lines and they will crank right up.
