The engine cylinder head (if original) will be marked with the distillate part number (or Kero part number) under the valve cover. If it was originally for tractor fuel (distillate, or Kero) it will also have a second gasoline tank in front of the main tank, under the main hood, with a hole for the tank neck. and bracket to hold the tank.
THe carb if adjusted to float level, and clean, should work well with gasoline. adjust the load screw inward to limit fuel delivery. If it still will not lean out, someone may have reamed the jet, or installed the wrong main jet. Jim
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
