Re: Farmall M hydraulic fluid
Posted by farmallhal on August 04, 2010 at 07:53:32 from (76.3.52.60):
In Reply to: Farmall M hydraulic fluid posted by Dan in Ore on August 04, 2010 at 07:30:32:
Dan, Use SAE 30 non-detergent motor oil which won't foam like a detergent will. I usually find it at the farm and home type stores unless you have a very good auto parts chain in your area of Oregon. 6 quarts should be the correct amount per the owners manual. If you are lucky the original dipstick will still be on your tractor beneath the filler cap, Hal.
