Re: 1066 3 point wont stay up
Posted by IaGary on August 06, 2010 at 02:16:02 from (69.63.16.90):
In Reply to: 1066 3 point wont stay up posted by tbone8 on August 05, 2010 at 22:25:04:
Are you talking while it is running or while it is shut off?
If while running, pull your draft control level back so it will keep it up. You will notice that the draft control will bounce it back up after it drifts down a small amount. If it doesn't cycle to often I would not do anything. If it is a constant up and down motion then it needs fixed. And is most likly the piston.
If while shutoff, there are very few out there that stay up when shut off. And I wouldn't worry about it till it gets bad while running.
