Posted by D Slater on August 06, 2010 at 06:16:23 from (71.164.42.95):
In Reply to: H front pedestal posted by Stuart Bruny on August 06, 2010 at 05:12:17:
Only problem could be the rims, a 51 H probably had the rims with 3 loops that bolts go through to install on the wheel. That type rim will fit the 350 wheels. If you happen to have rims with no bolt loops, they won't fit the 350 wheels. Only differences if comparing the same type wheels in appearance, would be wheel castings were made stronger on later wheels, mainly at the rim mounting holes. If comparing notice the casting is thicker there and longer rim mounting bolts were used. If you have the same rims I would bolt it on and not worry because after 1952 or 53 IH only sold the later castings as replacement wheels for any H. Some real late 51 tractors may have come with the thicker wheels. IH used the term for right or left side of tractor as with the operator sitting in the seat. Don't know which way Gordo means.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
