Re: Poor Running Farmall 300
Posted by mkirsch on August 06, 2010 at 12:33:10 from (64.80.108.56):
In Reply to: Poor Running Farmall 300 posted by ed in cny on August 06, 2010 at 09:15:35:
My philosophy is to fix the obvious known problems first and odds are that by fixing them the mysterious "gremlin" problems will be fixed at the same time...
Case in point, if you need to jump start the tractor to get it running, then the battery isn't in too good of shape. Weak battery means weak spark which could cause the tractor to run poorly. By ignoring the charging/starting problem and chasing after gremlins, you may well be wasting perfectly good time and money.
Try charging the battery up the night before you want to use it. It may well start right up on its own and run like a top!
