Posted by Val Taylor on August 06, 2010 at 12:54:22 from (69.28.44.145):
My tractor will at times not pull itself out of it's tracks, other times it pulls very hard and steady. I've checked hydraulic oil levels and all is well. Could this be a clutch issue or hydraulic pump? If I idle down it sometimes moves, the higher the RPM the worst the problem seems to be? Any help would be appreciated.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
