Re: More starting issues! 1948 Farmall H
Posted by El Toro on August 06, 2010 at 16:16:56 from (74.103.74.58):
In Reply to: Re: More starting issues! 1948 Farmall H posted by Justin M on August 06, 2010 at 14:55:04:
Did you remove the mag when installing the tuneup kit? The points should be set at .013" when the rubbing block is on the high point of the lobe. Have you checked for fire to your plugs? If there's no fire replace the condenser and check for fire again to your plugs.
If there's still no fire to your plugs your coil is probably weak or the magnets. The magnets need strong magnetism. Hal
