Re: 1066 3 point wont stay up
Posted by Owen Aaland on August 06, 2010 at 19:47:41 from (65.165.246.191):
In Reply to: 1066 3 point wont stay up posted by John - OH on August 05, 2010 at 22:25:04:
Remove the hitch link bracket from the rear frame (above the PTO) and look inside to see where the oil is leaking.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
