Re: Poor Running Farmall 300
Posted by ed in cny on August 06, 2010 at 20:34:28 from (173.50.60.254):
In Reply to: Poor Running Farmall 300 posted by ed in cny on August 06, 2010 at 09:15:35:
Thanks guys on the ideas. I haven't thought of the valve gap but have done so with other tractors and have had better results from that process with them. What's the gap I need to get? Am I finding TDC on #? piston or what? Someone able to run me through the process with this tractor?
I agree that maybe the battery could be the reason as well. However I am able to rule that out as it runs that way either way. I can tell when the life of the charge is going and when it's not. Agreed I could spend some time on the battery issue and will address that as well at some point.
As to any smoke out of the stack. I have to say that it's really clear or at least what a 50 + year old tractor can have. I see a hint of white smoke and am thinking it's oil bypass. That is only present when I have "give it the gas" and then it's back to clear. It really isn't much at all when I do anyways.
