Re: H light problem
Posted by Harold Evans on August 06, 2010 at 21:30:08 from (69.136.4.122):
In Reply to: H light problem posted by Tyler Jackson on August 06, 2010 at 16:58:47:
This sounds like a grounding problem to me. Can you take a test wire and run it from the light to the grounded post on the battery? If this fixes the problem, then simply run a dedicated ground wire from your lights to a good spot on or near the battery. I recently did this on one of my tractors where I was having intermittent problems and now everything is very stable.
When we expect a good ground to run through rusted and loose connections from one end of the tractor to the other, we are asking for trouble. Good luck and please report back on what the problem was after you've solved it.
