Re: More starting issues! 1948 Farmall H
Posted by El Toro on August 07, 2010 at 06:21:23 from (74.103.74.58):
In Reply to: Re: More starting issues! 1948 Farmall H posted by Justin M on August 06, 2010 at 19:40:59:
Have you ever removed the mag from the engine? You should remove No1 sparkplug near the radiator and bring No1 piston to TDC on the compression stroke. Hold your thumb over the plug hole and have someone to slowly crank the engine until you feel compression against your thumb. Then drop a plastic straw on top of the piston and watch that straw rise as the engine is slowly cranked. When the straw quits rising your engine should be at TDC on the compression stroke.
Pull the cap off the mag and see where the rotor is pointing. It should be at your No1 plug tower on the cap. Hal
