Posted by Owen Aaland on August 07, 2010 at 06:31:23 from (65.165.246.191):
In Reply to: 706 torque question posted by clattermac on August 05, 2010 at 13:35:24:
Since the steering is good the first thing I would check is the power brake valve. There is an orifice under the inlet line fitting to restrict the oil flow to one GPM. The 706 uses an open center brake valve so if that orifice comes out it can dump too much oil through the valve and cause loss of pressure in the TA system. Try shifting the TA while applying the brakes. If that improves the shifting the orifice may have come out. Remove the line and fitting to get access to the orifice.
Problems in the MCV assembly may be a blown gasket, broken spring on the pressure regulator valve, or a stuck regulator valve. The TA may also have too much leakage, usually worn sealing rings and bushing on the input shaft.
With the open center power brake valve you only have two GPM available to the TA. Later tractors used a closed center valve so they have three GPM available.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
