Re: H light problem
Posted by Janicholson on August 07, 2010 at 08:02:32 from (67.72.98.45):
In Reply to: H light problem posted by Tyler Jackson on August 06, 2010 at 16:58:47:
Use a piece of solid copper wire (12 gauge stiff) and bridge across each connection from the light bar to the bulb ground side. This process will find the faulty ground. The components that touch the light bar where it is sanded are now not making contact with the shell, or the internal connection to the bulb ground. Shiny is the answer, then some LPS corrosion inhibitor spray. Jim
