Re: 460 with electric ignition.
Posted by Janicholson on August 07, 2010 at 08:34:13 from (67.72.98.45):
In Reply to: 460 with electric ignition. posted by 730-TOM on August 06, 2010 at 18:14:55:
Owen below is correct. The likely problem is an alternator exciter current leak. A replacement alternator with 3 wire setup is an easy fix, and will charge as soon as the tractor is started. The electronic ignition is not involved with the issue. Jim
