Posted by Janicholson on August 07, 2010 at 18:27:26 from (67.72.98.45):
In Reply to: super c pto issue posted by backhoe man 57 on August 07, 2010 at 10:50:03:
You will need to diagnose it: remove the drive shaft from the tractor (it may (should have) a over running clutch on the tractor end of the shaft) if it does, make sure it is not broken allowing slippage. If it is OK, check the PTO shaft by turning it with a pipe wrench (tractor engine stopped, clutch out PTO in gear) If you can turn it (use a lot of force), it is broken internally. If not it could be that overrunning clutch slipping internally. test it again with more force. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
