F-20 With Belly Pump
Posted by SuperCmore on June 09, 2000 at 12:30:17 from (216.73.211.20):
I have a 39 F-20 with added belly pump off an H that works fine. Question...will a high pressure cylinder used with WD-45 AC work with this set up? I know an old IH a cylinder WON'T work with the old AC high pressure, but will the other way around work? Just a one-way pump, of course!! Thanks. SuperCmore
Post A Followup
: Re: F-20 With Belly Pump
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
