Re: Cub with noisy clutch
Posted by Wardner on August 07, 2010 at 19:29:21 from (4.154.235.169):
In Reply to: Cub with noisy clutch posted by brooksie on August 07, 2010 at 18:16:01:
That driveshaft is about three feet long and 1" in diameter. Any vibration can induce metal fatigue and snap the shaft near the front or rear splines. There is no center bearing to limit the vibration. Fix it now or fix it later at a higher cost.
I'd be looking at transmission bearings.
